Question about Bogen Communication Bogen / Manfrotto 785B 785B Modo Maxi Tripod
Stolen Part on manfrotto 785B.
I own the manfrotto 785B. The attachment which screws into the camera to connect it to the tripod was attached to my camera at the time my camera was stolen. I would like to replace this part. I reside in South Korea, how can I go about this?
    New Friend:
  • 63 Answers
You can get the quick release replacement. You need the 785PL. Check this site for parts order.
http://www.tripodquickrelease.com/Bogen_Quick_Releases.htm
Hope this helps and get you back into action.
Andrew
Posted on May 26, 2010
6ya staff
SOURCE:
Video camera attaches backwards
Is the anti-rotaion pin in the way? It is the fixed pin that may not allow you to mount the camera correctly,if the camera does not have an anit-rotation hole. You can remove the pin and it should work fine.
May 13, 2014 | Manfrotto Modo 785B Tripod
How do I release a Manfrotto 501HDV head from a tripod
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Oct 27, 2012 | Manfrotto 503HDV Head and 351MVB2 Tripod...
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
May 09, 2010 | Photography
Attaching head to tripod
video cameras come with a 1/4-20 threaded socket in the.  Make sure the 3066 has this size screw projecting form the place where the camer is attached.  The two Manfrotto should be compatible
The only time fitting together becomes a problem is if you are into the heavy duty professional equipment.
We especially like the Manfrotto fluid heads and have several in our facility.
Nov 01, 2008 | Photography
Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Jun 03, 2008 | Manfrotto Photography
Bogen Communication Bogen / Manfrotto 785B 785B Modo Maxi Tripod Logo
177 people viewed this question
Top Bogen Communication Photography Experts
Ekse
Marvin
Marvin
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
