When I try to play a Blue Ray DVD movie on my Sony BDP-S301, I get the No Disc message on my screen, after trying different DVD's and BR Movies as part of my troubleshooting the problem continues, What should I do next?
Use a q tip with a little bit (not dripping) of rubbing alcohol. Eject the tray,unplug, look for laser,you may have to do a little bit of disassembling,but have no fear if you have a digital camera at hand. Use the q tip and gently spin it between your fingers and lightly press against the laser lens. Let the lens dry and look for streaking,if it streaks,youre using too much alcohol. After cleaning,test with an audio cd,then regular dvd,then blu ray. If it works awesome,if it doesn't then the laser is most likely burned out.
