Silver Cross Balmoral Pram Carriage Stroller Logo
Posted on Nov 01, 2009
Were can i buy a replacement handle for my daughter silver cross dolls coach built pram
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
503
Points
Look on this website www.vintagepramfan.com and if you mention the problem with your pram in the comments section (after each post) I am sure they can help with this query and any others about these kind of prams.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2430
Points
8
Try pram restoration. Silvercross heritage.
  • Anonymous Jul 13, 2011
I have been given a navy blue silver cross coach built pram, i need to find out what kind it is because it needs a apron. it has a sticker on the bottom of it with numbers on but this means ? to me. please...
The sticker on the bottom is only the chassis number and usually the date of manufacturer. Is the pram one where the body detaches from the wheels and do you know how old it is? Or is it the boat shaped body with big wheels, which doesn't detach from them? (Similar to the picture on here of the Balmoral). Or is it one where the body detaches from the body? If you look on EBay under Silver Cross prams you should be able to identify the model. There are also aprons often for sale on there too.
1helpful
The handle bar on my silvercross linear sleepover pram system has snapped, where at the height adjustment buttons, can i get a new handle for my pram?
hi bex_901. you can contact the retailer where you bought thestroller. you can also email silver cross about the new handle for your pram.surely, they have an available replacement for the handle. please check the link iprovided below. thanks for using fixya. good luck.
https://www.silvercross.co.uk/contact/spare-parts/
Tyre back on wheel?
onto the rim or onto the shaft ? if you can't get the rubber tire onto the rim itself.... heat it by putting it in hot water... then try.
2helpful
How to replace tyres on a silver cross vintage pram
hi echapman61... here's a link for silver cross where you can email them about thespare part.hope ithelps..please let me know the outcome. thanks for using fixya..goodluck!!
2answers
Old 50s dolls pram hood repair
Hi Libby,I have a dolls silver cross pram that needed corners i got mine from ebay i'm sure they still have them hope this helps you.Kath
2helpful
2answers
Silver cross
Babybirds.co.uk stock a full range of replacemnet parts for silver cross coach built prams baby and dolls or heritage prams there is a link through the silver cross web site. but they do tend to a little more expensive.
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 • Baby Gear
1helpful
2answers
Vintage dolls pram poss a silver cross?
I have a Silver Cross dolls pram 40 years old in mint condition, this one was made in England and has no sign of wear at all. If anyone is interested? 07954 168181 I have kept this for my Grandchildren but they are all boys!
May 18, 2008 • Baby Gear
7helpful
4answers
Silver cross 3d pram system in jet sport
i have a silver cross travel system and can only seem to fit the rain cover on properly when its in pram mode how do you do it when the car seat is attached
2answers
Silver cross coach built pram
I am trying to get 2 16inch wheels & 20 inch wheels for a 1971 Sliver Cross Kensington
Top Silver Cross Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Silver Cross Baby Gear Expert? Answer questions, earn points and help others
