Question about Whirlpool Duet GHW9150P Front Load Washer
F-26 flashing - Whirlpool Duet GHW9150P Front Load Washer
  • 107 Answers
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Posted on Nov 01, 2009
My Copier Sharp MX-2700N displays print quality Automatically adjusted and it wastes so much time to initialize. How do i fix it?
might also be the it has to have its firmware re-flashed have tech come and check it out and have a good cleaning done.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 12, 2015 | Sharp MX-2600N Laser Multifunction Printer...
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Protron PLTV-26 gets power but nothing else. No
i have a protron lcd menu light keeps flashing but tv wont come on any help would be appreciated.
Sep 06, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
I want lock code for sony ericson k660i
First download this software: Ultimate Unlocker v1.01 by Cruiser Team(search google its free!)
Follow the example given below:
Successfully unlock K660i (A2) 17:25:25 Ultimate Unlocker v1.01 by Cruiser Team 17:25:26 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:25:26 Initializing... ! 17:25:26 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:25:26 2. Choose the phone model ! 17:25:26 3. Select the desired options ! 17:25:26 4. Please connect the phone either via USB while holding 2-5… ! 17:25:26 - or via a serial cable and double-click on it in the device list 17:25:34 Connecting via Generic EMP USB Flash Device (USB1)… 17:25:34 Device driver version: 1.1.0.12 17:25:34 Device driver date: 9-25-2006 17:25:35 Connecting to the baseband CPU... 17:25:35 Entering baseband CPU service mode... 17:25:35 Detected chipset: DB3150 17:25:35 Boot mode: ROM 17:25:36 Sending loader... 17:25:37 IMEI: xxxxxxxxxxxxxxx 17:25:37 OTP CID: 52 17:25:37 Product type: Retail 17:25:37 Effective color: Red 17:25:39 Sending loader... 17:25:40 Communicating with server… 17:25:44 Remainig credit (supreme): 1.00 17:25:49 Remainig credit (supreme): 1.00 17:25:49 Converting phone to blue… 17:25:49 Please reconnect the phone (disconnect, connect while holding 2-5) 17:26:01 Sending loader... 17:26:02 IMEI: xxxxxxxxxxxxxxx 17:26:02 OTP CID: 52 17:26:02 Product type: Retail 17:26:02 Effective color: Blue 17:26:04 Sending loader... 17:26:08 Code NCK for relock: 9753585490502778 17:26:08 Code NSCK for relock: 3889412532359257 17:26:08 Code SPCK for relock: 3171907565654182 17:26:08 Code CCK for relock: 6478061648618760 17:26:08 Code PCK for relock: 3949070691496765 17:26:08 Code ESLCK for relock: 9101944641118096 17:26:08 Code NCK for unlock: 9012406338647640 17:26:08 Code NSCK for unlock: 2040670855123632 17:26:08 Code SPCK for unlock: 0923191541634191 17:26:08 Code CCK for unlock: 4556970785063717 17:26:08 Code PCK for unlock: 1754665636774190 17:26:08 Code ESLCK for unlock: 2257853277910517 17:26:08 To enter a code, type < * * < on the phone with SIM-card inserted 17:26:09 Turning off the phone... 17:26:11 Done. ! 17:26:11 Please disconnect battery and cable from the phone!
Alternatively you can do this:
hard reset *2767*3855# (this erases all ur data, you can preserve ur data by takin a backup.)
Aug 23, 2009 | Sony Ericsson P1i
Unlock code k660i on 3 network
17:26:11 Done.
Aug 22, 2009 | Sony Ericsson K660i Cellular Phone
My 26in Protron lcd has sound but no picture.
the symptom of the flash will be faulty invertors. start checking power supply output and resistance across invertors
Mar 31, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Gaggia Syncrony Compact
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
May 18, 2008 | Gaggia Syncrony Espresso Machine
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Whirlpool Duet GHW9150P Front Load Washer Logo
1,234 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
