Blue convergence off i can adjust manually but there is a blue halo around everything
Where do you put this projection tube coolant?
A halo as youre refering to usually means your coolant in the effected tube needs replacing. Can be purchased at http://electronix.com/ . Let me know if I can be of any further assistance.
Its called projection tube coolant. This link will take you to the actual catalog page where you can copy the part number, then return to the home page and make your purchase.
http://www.matelectronics.com/cgi-bin/ss...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Same problem here...just happened tonight. My convergance works yet it seems the blue tube has a "sag" in it. Could this be the fuse mentioned in some of the solutions above?
what is the part called. I am very amiture at this so when i go to the website i will know what to look for
thanks,
wade034
