Tv has no power-it was running perfect then just went black yesterday morning-light sensor blinking blue not stesdy blue light-I had to leave for the day- got home late last night -still blinking blue couldn't turn on - power source ok - manual says to unplug 30secthen turn on -it tries- light sensor goes red then blue -then off all in about 5 seconds-now light sensor is not on at all- this is a Hitachi plasma tv bought new in Jan and has run perfectly til yesterday
What was the fix for this problem? What did the repair shop do to remedy the problem?What was the fix for this problem? What did the repair shop do to remedy the problem?
You can't post conmments that contain an email address.
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Q510, Ta1316 is your sync processor and probably the problem you're having here. It's a common one for this unit and you could pull the board and check the solder connections it has with the foil - - but you may need to replace it...
