Question about Toshiba 65HM167 65" Projection Television
Toshiba 65hm167 black screen with video input
Toshiba 65hm167
can see menus, led light is solid blue, without video input can see "no video signal"
this means it can't be the lamp right?
  • Anonymous Nov 11, 2009
    Toshiba tec-support indicates this is a main PCB (printed circuit board) problem. The advised me to unplug the TV to clear the error. This worked for me.
    Novelist:
  • 157 Answers
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
Posted on Nov 11, 2009
6ya staff
SOURCE:
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Yellowlight blinks 3 times on my toshiba 62hm116
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Jul 04, 2012 | Toshiba 65HM167 65" Projection Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Yellow light blinking on tv will now come on
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Apr 26, 2010 | Toshiba 65HM167 65" Projection Television
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Toshiba 65HM167 65" Projection Television Logo
361 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
