32" Emerson LCD TV (720p 2 yr's old) has sound but poor then no image when powered on. images have bad color, (overexposure/streaky) and seem to be in slow motion. Picture goes off within one minute of power up, but sound stays on afterwards. tried bypassing DirectV box and DVD box and and changed electrical outlet, but nothing helps. Problem developed instantly.
SOURCE: my emerson tv standby light is on the power light flashes twice
I have this problem too with my 32 inch Digital LCD TV.
SOURCE: WHERE To BUY power boards for emerson 32" FS TV
I had the same problem. Mine gave out in 4 months. Those boards are hard to find right now. Google the the board# BA71FOFO1042 and someone like (buyjimmy.com) I think will sell TV parts. If not, you can fix the board itself like I did. Mine was a bad inverter transformer. If you need the parts# for anything let me know, I have the Service Manual for the TV. Good Luck
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
