For some reason when you are not able to scan an item of yours.
To fix Brother Printer Error TW006 which has arrived with the scanner when scanning with the ControlCentre 3. When you try solving to scan a document using Brother ControlCenter 3 software but it failed to connect to Brother Printer. Interesting thing is when you attempt to configure the device remotely using same Brother ControlCenter 3 it worked actually without any issues. Initially there can be some form of firewall issue either on computer system however that was not the issues. As you are trying to scan a document from the ControlCenter, the following error message may occur under certain circumstances "No connection to the device is possible [TW006]". Printing is, never possible without problems.
If your device is switched on and ready for operation, this can be a problem with the DNS resolution. Even if the MFC has been installed using fixed IP, as recommended above, the scanner app may use the node name. This leads to this problem under certain circumstances. As the problem, usually comes in the MFC Model of Brother Printer. Connect to
http://www.brotherprintersupportnumber.com/
for more clear understanding of the issue.
Follow the steps to troubleshoot the Brother Printer TW006:
Step1: Make sure your computer device is not using multiple network connection
Step2: Reset the Twain Settings using the Twain Reset Tool
Step3: Enable the Windows Image Acquisition service in the registry
Step4: Reinstall thebrother machine software and drivers
The steps mentioned in above section should be sufficient to fix the error code TW006 but in case you fail for immediate and instant you can call
Brother Printer Customer Support Number 1-800-213-8289. Brother Printer Support Phone Number 18002138289 Repair Service
