The Auto knob maybe mechanically stuck or the internal switch may be defective.
Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement.
Do rate the solution.
Samir
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature.
I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
I looked up your monitor and that resolution is not supported. Which means auto adjustment will not work.
The video card will compensates for that, and resizes the picture for a display resolution that shows the picture anyway, (if it can) but isn't what you wanted. Your best bet is to use resolutions that are compatible, or get a (different) monitor.
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Check your refresh rate in your display driver properties. Try changing it to one of the available selections other than to what it's currently set to. It could be that the monitor is trying to match the signal received but can't quiet do it correctly.
Try wiggling the auto adjust button on the front of the monitor, it sounds like the button is jammed against the switch causing it to auto adjust over and over.
Hi, In case you have connected both the DVI and VGA cables to the back monitor can cause this problem. Try unplugging one of the cables and check if the problem gets resolved
