Question about Samsung LN-S4041D 40 in. LCD HDTV
I have a new Samsung HD tv and have hooked up my DVD player. I have a Directv remote. How do I watch my movies now?
  • Michael Pahl May 11, 2010
    You have to program your remote to your Directv remote first. Then look at which ever port you plugged the dvd player into and you will have to change the input on your TV to that setting. Then you should be able to watch movies. Good luck!
  • 11,361 Answers
You will still need to use your SAMSUNG remote to switch the source inputs since I do not beleive the DIRECT-TV remote has full function of the SAMSUNG remote.
Posted on Nov 02, 2009
Testimonial: "I will try this when I get home tonight-thanks!"
  • Samsung Master
  • 5,638 Answers
Restore Deleted Files on Samsung
The Android data recovery
could be best helper to recover deleted files on Samsung thoroughly. It is a professional data recovery tool good at restoring deleted data from Android device. A various types of Android data are supported, for instance, contacts, text messages, photos, videos, call logs, WhatsApp messages, apps data and more. It could be used to perform Android data recovery for any data loss causes.
More importantly, this program have other function, which are Android data backup & restore, recover data from broken Android. It is compatible with almost all models of Samsung and other Android models, including Galaxy S9/S8/S7/S6/S5, Note 9/8/5/4.
LEARN MORE
Posted on Nov 19, 2019
Anonymous
SOURCE:
Need to reprogram my remote to my Samsung tv. No manual
How To Program Your Samsung Universal Remote
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 5, 2013 - You can program your Samsung television universal remote control to... Note: Your remote may have separate buttons labeled Cable, DVD, ...
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote-c...
DirecTVHow do I program my DIRECTV remote control? Print. Email ... DIRECTV RemoteSetup to Change the TV Input Source. If you can ... Still need help? Contact us ...
HOW TO RESET YOUR TV REMOTE CONTROL - YouTube
? 3:15
https://www.youtube.com/watch?v=CnFfo8-3GC4
Feb 11, 2012 - Uploaded by SlimfromMrRemote
However, if this does not work and you do need a new TV remote,... thank you so much my control samsung tv AA59-00580A its working again ...
HOW TO PROGRAM SAMSUNG SMART REMOTE - YouTube
? 8:35
https://www.youtube.com/watch?v=asgS7NzQLi4
Jun 28, 2012 - Uploaded by Tampatec
Feb 03, 2016 | Samsung Televison & Video
How do I setup my dvd to mt tv, i use direct tv
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
I have a Funai Brand TV and I recently got Directv Cable installed and now I cannot watch a movie with the dvd player because the remote will not change to the channel?
Make sure you are using your TV's remote and pressing the Input or Video Source button. This will change the channel to the DVD input.
Hope that helps!
Jul 21, 2011 | Televison & Video
How do i go to input so i can watch movies on the dvd player
you should have a source/input button on the remote. Press this button and choose the input with the same name as the one you have the DVD player plugged into. Samsung TV's also have a button on the tv for source as well, it looks like a square with an arrow pointing into it.
Mar 08, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I just bought a samsun 40 inch tv and I wanted to watch cd movies but I can't find dvd player, I thought all tv had them now, how can I watch cd movies, do I have to get a dvd player to hook up to the tv?
Yes, you would need a dvd player or some sort of additional media player. They have alot of different kinds out now. You can even use your cable box to order movies, or you can even use a device that will stream movies instantly such as netflix.
Mar 02, 2011 | Samsung LN26A330J LCD TV
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Aug 31, 2007 | Televison & Video
Samsung LN-S4041D 40 in. LCD HDTV Logo
167 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
