SOURCE: black lines (streaks) printing on left of page on my ricoh 2000n
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
SOURCE: Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
SOURCE: how to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
You should replace the PCU if prints show any of the following symptoms.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Ricoh Aficio CL3500N is now
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
SOURCE: lines in printed copy on Ricoh CL3500N
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored. The corona wires are also integrated into the toner cartridge in many smaller machines
