Panasonic Lumix DMC-LC50 Digital Camera Logo
Posted on Sep 24, 2017
Cant transfer photos from lumix camera to PC
I cant seem to transfer the photos from my lumix DMC-LC50 camera to my PC. an using ulead. am using ulead photo explorer 8.0
it would show the pictures however it stops then gives the error message (not responding). thought at first i dont have enough storage space in my PC so i deleted old files but its the same problem. pls help ü thanks
  • Anonymous Jan 08, 2008
    Transfer from camera to pc
5 Related Answers
kakee
Michael Galve
  • 1269 Answers
  • Posted on Sep 16, 2008
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Anonymous
  • 155 Answers
  • Posted on Feb 09, 2009
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Anonymous
  • 11967 Answers
  • Posted on Apr 05, 2010
SOURCE: I would like to transfer photos from Lumix DMC-FX12
In the camera menu, scroll to "copy"...you have the option to copy the internal memory to a memory card.
Anonymous
  • 11967 Answers
  • Posted on Apr 13, 2010
SOURCE: instructions for lumix digital camera dmc-fx10
You can download the manual from the support section of the Panasonic website.
  • 102366 Answers
  • Posted on Apr 14, 2010
SOURCE: I need to transfer photos from my built in memory
Select "COPY" from the PLAY menu. Select the direction (in this case, IN-to-card). Select YES.
Install a Panasonic Lumix to my PC
You need the software that came with your camera. It is on a CD or DVD. You have to install that before you connect the camera. Some brands offer free downloads of the software, and updates. This software only works with camera's of that brand. If you can't find the software, the only thing I can think of is some free software like from Ulead, Pixir, BeFunkey, Gimp, Photoshop elements. Or if your camera does have a memory card, buy a external card reader and use that to transfer the pictures and videos to your computer. For that you don't need the camera software.
Get photos off my panasonic lumix
Photo transfer from the camera to a computer is usually done with a USB cable. For detailed instructions on how to transfer the pictures, check out the user manual:
Panasonic DMC FX8 manual
I have a Panasonic DMC-FX550 Lumix camera.The date and time show on the camera when i play the pictures,but when i connect the camera to the laptop and view them i cannot see the date and time.I have gone...
The camera screen is displaying the "metadata" for each picture as you view them. Your computer screen does not. However, when you download your pics to the computer, the metadata goes with them. If you hover your pointer over each file, the info will appear. You can right-click and get even more info. Some photo editing programs will even give you every detail including the lens opening and shutter speed, the make of camera that took the pic, etc.
4helpful
The camera is not transfering my photo to the computer
Use a card reader instead of your camera to download to a folder you create on your desktop.
1helpful
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Lumix® digital camera storage for
Lumix cameras use SD memory cards. The picture files are stored on the card which is located in its slot on the side of the camera.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
