SOURCE: I have a single lever Moen faucet where the handle
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
I assume the handle is lose. If that's the case, simply tighten the set screw. It's under the little logo thats on the faucet. use a 3/32nd Allen wrench
