My GE profile WPDH8800J doesn't hit high speed spin during a full wash cycle, in other words my clothes are always too wet. When I put them on for an additional spin it's fine, the spin TAKES OFF! and the cothes are a mere damp. I see a few other people claiming that their machines have balance issues but if that's my problem than why is it ok when i run a seperate spin?
SOURCE: Cothes are overly wet, doesn't
Please clean filter or/and check the drain pump for obstructions. 99% of the time it works
SOURCE: GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at [email protected]
SOURCE: no spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
SOURCE: MY WASHING MACHINE AGITATOR WON'T SPIN. I CAN HEAR
then your motor coupling has broken cost for part is about $20 can buy from your local appliance shop or order from REPAIRCLINIC.com
