the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray). If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
This is telling you to load Letter sized paper into the multipurpose feeder. Take the paper that is in the tray out and place in the correct Letter sized (8.5"x11") paper into the tray
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray). If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
load mp feeder means To load the Manual Paper Feeder
You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
You can change the settings to automatic paper feeding to get rid of this error.
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
