That usually means you need to replace the image drum or the corona wire or fusor It can also be a toner cartridge problem.
None of these are hard to do but they can be pricey for the image drum.
If you just replaced a toner or use a non oem replacement it could cause this. If you print say 10 pages and it fades out then I would look at replaceing the toner cartridge even if new. There is a brush or scraper than collects the extra toner and when this wears on refils or isn;t as good on off bands then you can get this.
This is caused by partially blocked ink nozzle. So Apply a folded tissue paper to the ink nuzzle and press
firmly. If the tissue comes off well blotted with ink it means you still have a
good amount of ink in it and the nozzle is not blocked; ink is flowing well. If not blotted or scantily
blotted, it means ink is really low or nozzle is blocked or partially blocked. To be very sure of
this, place nuzzle in a plate/saucer with a bit water so that the nozzle is
soaked. Leave for about 10 minutes. Then apply the tissue again. If still not
well blotted it means ink is really low or empty. If new you should return it
for a replacement. In the case of blocked nozzles, the procedure may be
repeated over to get results.
Good luck & God bless!
