With a gas dryer taking to laong i usually start with the gas ignitor and valve...
since you are getinng things dry we can assume youir ignitor works'so then go back to gas valve
there are two coils on it the boost and assist
again since things are getting dry we again assume your boost is good but your hold is probably getting week
i would replace both at the same time just to be sure
you can order them at
www.appliancepartspros.com
ill be here if you need help
have a good day
Testimonial: "I took it apart again to see if I broke the hot surface ignitor put it back together lots of heat coming out of exshast never tamperd with gas valves "
