Since all of the off air channels went digital in 2009,your unit will not bring the antenna channels in because it does not have an ATSC tuner. The specs show just an analog tuner. Otherwise you would use the ez set up menu.but in this case you need to upgrade the unit or look for a ATSC set top converter box
There are several models on several generations of Zenith manufactured LCD projection tv's. Without knowing the exact model of yours i can't be sure but in most of them the Lamp life counter is reseted this way: with the tv in stand-by, you press the "?" key on the remote then immediately you press 9,8,7,6 and then the OK. If the procedure was correct the 3 lights on the front of the tv will blink to signal the end of the reset procedure. In others , hold down the Mute button on remote and Enter on TV at the same time for a few seconds, you should get a screen prompt asking if you want to reset the timer for the lamp.
you do not give the model number for a better diagnosis the most common cause of this problem is the invertor or at worse the screen its self. If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
U in bad luck, cost about the same as buy a new one,because Tv compannies don't sell out LCD picture Screen.If they do, cost about the same as a new tv.Only lucky is if buy it tv good LCD screen,but bad pcbs.
From the rear of the set, on the very right hand side of the input panel, you will see a 3.5mm jack that says DC 12 v input. That is where the small power cord gets plugged into.
What type of Universal Remote Control can I purchase for a ZENITH Concierge, Model H2735DT, TV?
Please supply brands and model or serial numbers of remote types.
Thank You,
Ken Ducre
e-mail: [email protected]
