Tray Lock feature is on.
While unit is off press and hold 'stop' button for 5 seconds. You will see 'UNLOCKED'. To lock it again hold the 'stop' key again for 5 seconds 'LOCKED' will appear.
hello
Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
You can lock the tray and prohibit the unwanted disc ejection. On the center unit ONLY: While the system is turned off • The system turns on and "LOCKED" appears on the display window. • If you try to eject the disc, "LOCKED" appears to indicate that the tray is locked. To cancel Carry out the same operation again. • The system turns on and "UNLOCKED" appears on the display window.
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
