Most toners have a wing or *** or? that contacts a sensor in some way when the lid closes to tell the machine a toner is present. ive had these pieces broken off on new toner or the toner sensor may be disloged from its seat. check around the perimiter of the lid to find the sensor then see if anything is present to trip the sensor. if its broken off stick a q-tip in the sensor that will get you printing til you can replace the part
SOURCE: Ricoh 2045 Doesn't recognize new toner cartridge
Please check the Toner supply unit.
If necessary dismantle it carefully and clean all the toner inside it and clean all the small parts. There must be 2 small mylars attached inside to the cover toner supply unit - If not there that's the problem.
Check also for broken parts.
Try replacing the whole toner supply unit.
Good luck and please rate me, thanks.
