Dishwashers Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Bosh dishwasher seems to be stuck in the drain cycle. What should I DO?
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367514
Points
3700
Check your flaot valve,, it just may be stuck in the up position, this sometimes will happen from a peice of glass or a fork i even seen it just get stuck
but if its pumping that float valve must be in th up position
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Dishwasher fills with water... stops...(when it should be washing) then drains. Seems like timed cycle is working. justdoes not wash.
you have a sensor and it is restricted behind the bottom panel you see a rubber hose about 1/4'' in size remove and blow through it unless it a Bosh unit some how water gotten into the motor area this is cause by a plugged drain hose
Bosh dishwasher not working
It is possible. It is also possible that the water temp is too low and it is taking that time to heat the water. If it seems to be making a humming sound the entire time, like it is draining, see my guide here to clear the clog. I too thought mine was not filling at first, but these have a good number of drainage issues that are misdiagnosed as control board and fill valve problems.
3helpful
2answers
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Dishwasher drain issue
check to see if there is anything stuck in the drain pump. it not, replace the drain pump, as it's malfunctioning.
Sep 13, 2008 • Dishwashers
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Help with dishwasher
What Brand is it?
Dec 31, 2007 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
