SOURCE: broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
SOURCE: can't get charger cord to stay in phone to charge
I would recommend stopping by the shop you bought it at, or a cell phone accessory store. They will usually (more than likely) let you test out a charger, as it could be simply wear and tear on your charger. Doing this will address your problem as it will let you know whether in fact it is the charger, or the phone itself.
Good luck.
SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
SOURCE: The charger port on my lg voyager is frayed. If i
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
