David Struski Posted on Nov 04, 2009
Canon CLC 4000 Error code E013-0002
What is the Canon CLC 4000 Error code E013-0002 ?
montero
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Feb 11, 2010
montero
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
9
Helped
4424
Points
9
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
1helpful
CANON CLC 4000 ERROR 249-0001 ???? HELP !!!
E249
Cause The memory elements on the PCB are not connected, have poor contact, or
are faulty.
Description
0001 An error has occurred in the course of a read/write check of the
memory on the IP memory PCB.
0002 An error has occurred in the course of a read/write check of the
memory on the ED board.
Try to reconnect all connectors behind on dc controller.
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
1helpful
Canon irc2105 Error code E216-0000
hi i had a problem error code E810-0302 can you help
2helpful
Canon clc 4000 error code e194-0101
0101
When the pressure main thermistor fails to reach 80 deg C within the prescribed period of time after reaching 50 deg C during warm-up
you need your fuser rebuilt by a technician
2answers
I am looking for the Canon CLC 4000 service manual that I can download.
You might try www.justmanuals.com.It is a pay site but they seem to have everything.Good Luck
Error code E840-0010
the oil applying gears are broken replace all of them
CLC 4000 FUSER ERROR?
The problem is that the lower fusing roller has shorted out and it may have shorted out the DC- Controler. Did you resently replace the lower fixing lamp. If yes it is wise to replace the dc- controler at the same time. A suggestion from a Canon tech pub... Good Luck....
3helpful
ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
old marine
old marine
ZJ Limited
ZJ Limited
