Question about LG 42PX4DR 42 in. Plasma TV
LG Model DU-42PY10XH
One half of my tv screen is black with small colored lines running fron top to bottom. It has sound and a picture on the other half although the color is not good.. It looks like there is too much contrast. The set is only 2 years old and should last longer than this. Any suggestions?
Thanks
HD Dane
  • 1 more comment
  • Coronag Mar 27, 2008
    I had the same problem ever get it fixed?
  • Coronag Mar 30, 2008
    I have the same problem And found a semi-fix. I flip it over and turned it on and gave it a secound then fliped it upright. it worked for about 2 hours then did the same thing.
  • redwagon02 Dec 10, 2008
    Mine just started having this problem last week. A 3k tv that only lasts a 3 years. :(
2 Suggested Answers
6ya staff
SOURCE:
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
Posted on Jul 16, 2008
Lg plasma DT50py10. When turning on bottom half of screen is snowy and has lots of white lines for approx 20 min then it goes away. Top half of screen is normal
sounds like your bottom buffer board is on its way out .
Will also need to check the y sus board as this some times causes the buffers boards to fail.
May 24, 2011 | LG DU-50PX10 50 in. Plasma HDTV
My TV Screen just turned off, but I hear the sound, have no menu.
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical rainboow lines on the left half of the screen
its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.
Aug 31, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
The picture is gone, black screen only
have a du42py10x and i have no pic or sound take the back of and only 2 littel ligh on bottom com on
May 30, 2009 | LG DU-42PY10 42 in. Plasma HDTV
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Colored Lines
Hi
You have defective vertical output IC. and 1.5ohms resistor. this two parts need to replace a new one.
No other...
Thanks!
Jan 08, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Lost half of picture
Jerry G.
May 24, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
LG 42PX4DR 42 in. Plasma TV Logo
142 people viewed this question
Ekse
RONALD CARTER JR
