Electronics - Others Logo
Anonymous Posted on Jan 04, 2008
My new mini sd card wont work.
Hi. i have bought a kingston mini sd card and was using it fine. then after a few days it didnt want to work on the computer. it still works on my phone but when i plug it into the computer, nothing shows up. when i put my old mini sd card into the computer it works fine. i can plug my phone into the computer and go to the phone browser and then into the memory card but it is slow and i would rather plug the memory card into the computer and have the window pop up(auto-play). if anyone knows whats wrong, please help. thanks.
  • 1 more comment
  • Anonymous Jan 05, 2008
    i havent formatted the card ever on my pc and have formatted it on my phone. on my old memory card(the one that works fine and always has) there is a program(SD Content Package sd_apac - ) and i think it is something important.
    Guys. i fixed it. i removed the password.
  • DEVIL_EYE212 Dec 25, 2008
    want to format sandisk pro duo memory card from my sony ericson w800i
Anonymous
Level 2:
Champion:
  • Expert 217 Answers
  • Posted on Jan 04, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
217
Questions
0
Helped
104459
Points
312
A virus maybe present in your card, try to format the card IN your camera not in your pc. [:0)
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
5helpful
EasyShare C743 Digital Camera: I just bought a new 8 gig Kingston SD card for my ...
The C743 is only good to 2 GB other models of Kodak can use the larger cards but not the c743
SD card wont load on my t-mobile G1
try to go to a free check up cellphone repair...
check if your sd card slot is working fine...
if not you know now what is the problem...
but before it...try to fix it by yourself...just make some little adjustments...
I put songs on my micro sd memory card but my phone wont readthem
Found this youtube training video exactly how to do it:
http://www.youtube.com/watch?v=7pefPyXwmyo
There are a few tricks, such as formatting the SD card in the phone first, to create the special media folders; deleting the finger print file; playing the files in vcard on the phone.
Also, if the mp3 files come from iTunes and were purchased from the internet, they may be encrypted so they can only be played on the computer they were purchesed from - they will need to be burned to CD, then ripped back (removes the security, and some sound quality loss?), or use a special purchased tool to remove the security (there are tools out there, I just haven't bought/used any of them).
2helpful
Have an R4 card but cant get it to work
Re R4-III upgrade .I have got mine to work today after 6 days. need to go to memory bits to download files
need 5 files
  1. moooshell
  2. my picture
  3. r4
  4. r4 eng
  5. r4.dat
looking inside some of these files above to sort files.
from lucydun
  1. r4 eng
SD card for TT one XL
Card needs to formatted using fat32 in windows formatting options, then copy and paste your back-up files one by one to your new card.
Hope this helps
SD SLOT WONT READ 4GB MINI SD REG SPEED
try the 4gb card in a camera or phone. If the card is formatted in fat, it wont be recognized as the fat has a gb limit under 4 I believe. May want to reformat it in a camera or phone with fat32
My kingston mini sd
replace it sumtimes it happends when u drop it
24helpful
16answers
How to remove write protection in mini sd card? when process in running
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
2answers
New SD Card wont work - all the others I have do!!
I believe any SD cards larger than 2Gb are technically SDHC cards, which are not compatible with all cameras. Kingston is a decent company so I'm guessing it's not because the card is a dud. If your camera doesn't advertise SDHC compatibility then I don't think you can get the card to work in it.
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
