My camera says the my memory card is locked.?? i dont no how to unlock it
My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The camera still indicates card locked with a new card inserted.
My camera says that my memory card is locked. This is after, I imported a few videos that I recorded with alot of pictures. I do this alot, but for some strange reason, now it says that my 'memory card is locked'. Please, help I don't know what to do!
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
I just got done fumbling around with the same problem. All you need to do is take the card itself out of camera and there's a mini switch on the side of the card that slides up and down for lock and unlock.
my memory card says its locked. how do i fix it?
Camera says the card is locked but it isnt!
What do I do?
