SUDS = suds detected during wash cycle.
Do you see suds visible in the drum?
Do you have any other failure codes appearing?
Unplug unit and plug it back in attempt to run the rinse cycle. If it does not work it could be a clogged filter.
Remove lower front panel place a pan under the white filter. located near the pump. Remove the unit and clear any debris.
