Freezers Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an upright Freezer ehere water collects in the bottom of the freezer it doesn't evaporate but form a solid block of ice -there is no drain plug - how and how often do I check for water to keep the ice from forming??
Ginko
Level 3:
  • Maytag Master 19,396 Answers
  • Posted on Nov 06, 2009
Ginko
Maytag Master
Level 3:
Answers
19396
Questions
25
Helped
8075282
Points
55462
Usually there is a little drain plug.
Water must not be collected. If this fridge has fan assisted system with damper motor, then it is not suppose to make ice at all.
Let me know fridge make and model, so that I can be more specific.
Thanks.
  • Anonymous May 12, 2012
    Maytag Freezer MQU1556AEW L1
We have a Crosley WCF20/F upright frost free freezer. We get ice buildup on the bottom Shelf and can't pull the basket out. Is there a drain plug or something else? The freezer freezes all food
A frost free fridge or freezer has a heating panel that is switched on for a short time at the end of each cooling cycle to melt any frost that has formed over the evaporator.
The resulting water droplets are channeled through a drain to be collected in a tray mounted on the motor where the heat from the motor will evaporate it.
The drain of your freezer is probably blocked and has caused an ice build up. You will probably have to at least partially thaw and de-ice in order to find the drain and clear it. This is especially difficult as cold plastic is very brittle and easily broken. Great care is needed when clearing the drain as it is possible to dislodge the drain tube and if unnoticed it will saturate the insulation and render the freezer inefficient at best...
2answers
Model EVL201NXRQ05 serial eww4020663 WHIRLPOOL UPRIGHT FREEZER - Freezer which is having ice freeze on the bottom of the freezer. What can I do?
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
1helpful
Ice collects in the bottom of the freezer not allowing door to shut
BA Baker... hello,
Ice collecting on the bottom of the freezer.. is not such a terrible thing...
(Probably means the defrost is working... (merely not EXITING)).
New refrig or unfamiliar refrig could cause deeper analysis...
but if ...
If this is not a new device... and has been happily tending to it's own needs (evaporating well) for a while (months would be re-assuring)...
Then you are MOST probably looking at a clogged evaporator drain... (usually easily fixed by negotiating "WARM" (not hot) through the bottom vents slots of your freezer section.
Looking under your Refrigerator/Freezer... or consulting your owners manual... Locate your defrost "catch" pan...
It should NOT be dusty...
(easily tested: clean paper in tray...
Still clean tomorrow = clogged drain (pan is watered daily).
Close inspection should reveal a tube descending into it.... This is where you will watch for your patiently applied doses of warm water to appear... (near immediate).
It may take several doses... because ice can also have formed over the drain... Be persistent... You will be proud.
Please comment me back... I really like REFRIGERATORS/Frzrs...
few appliances tend to themselves so well (adorable).
Samsung RF4287HABP User Manual
Sheet of ice forms on bottom and red light comes on Does not drain out, the reservoir is small black box
Your drain probably is stopped up with debris. The reservoir just catches the water and then evaporates. Clean the drain out with a small brush and thenour a cup of water down it to clear the line.
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
3helpful
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
2helpful
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Water pooling and freezing on bottom of freezer. Cools poorly.
Check door gaskets if sealing properly? Check to verify freezer is level? If all of the above are fine then look at your drain for the condenasation. It's located at the bottom of your back wall underneath the aluminum evaporator that the cold air comes from. (You will need to remove the back panel inside of freezer wall To get to the drain. It's probably plugged and frozen over. Do not use a chisel or knif instead take a cup of hot water and pour it Oder the drain area and let it sit. (Your freezer will not be running for an hour or so so think ahead or work fast). That being said you have to unplug unit first :-) once you remove all ice push a straw or something through drain to verify its draining through. You can also flush more water down it to watch it drain showing you that it's working. Start with this first.
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
