Washing Mach... Master
- Posted on Nov 06, 2009
Re: Solution for washing machine
- remove top cover.
- Remove soap dispenser draw.
- unscrew the screws securing the the soap dispenser to front console.
- Pull timer dial off, noting position of symbols.
- slide console panel to right, and lift up out of way of front panel.
- Undo 3 screws securing top of front panel.
- undo 2 screws securing door interlock to front of panel.
- Remove plastic clip securing door seal to front of panel.
- remove wire clamp band round front of door seal.
- Undo 3 screws at bottom of front panel securing it to cabinet .
- remove front panel.
- Unscrew thye top wire clamp band securing the seal to drum front.
- remove door seal.
- Fit new door seal, making sure the drainage holes are at the bottom dead center.
- reassemble in reverse order.
- Please rate my solution.
- Thanks.
