Ew100 receiver is getting siganl but no sound is coming through
Ew100 receiver is getting signal but no sound is coming through the system... tested channel with second ew100 works great went through trouble shooting cantt figure it out
If you area aligning your dish yourself go to point dish screen ( menu 6-1-1) then highlight satellite and choose 129, use the signal meter and dish adjustments to locate 129 by getting a green siganl bar, (note: be sure you are standing behind your dish when aligning and not in front of it)
Add a DI box to clean up/boost the signal of that mic. If all the channels are doing this, get a bigger (more watts) amp so that you have more headroom.
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
You need one of the following pieces of hardware: "TV tuner" or "Frame Grabber" or "Video Capture". It should come with appropriate software for at least one version of windows.
Make sure that your antenna is in a line of sight such as a window. I know Sirius works in an Easterly direction for line of sight but I think XM works in a Westerly direction for line of sight.
The system has a buffer in it so it can take 5-10 minutes to lose the signal if it does. Keep an eye on the meter.
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
