SOURCE: no sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
SOURCE: LG32LC2D - Sound slow to start
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
SOURCE: cant get 42''lcd telly to let me play ps3 threw hdmi cable
You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
SOURCE: 32LG3000 No sound,no DTV
check ur sound volume also if sound is muted this all can be done by ur remote controll
