Frigidaire FRS26R4A Side by Side Refrigerator Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water tube to the dispenser has came unhooked in the door. how do i get inside door to hook it back up.
irsheye
Level 2:
Sergeant:
Champion:
  • Expert 323 Answers
  • Posted on Nov 07, 2009
irsheye
Expert
Level 2:
Sergeant:
Champion:
Answers
323
Questions
Helped
86685
Points
800
Around the edge of the door there should be screws holding on the SKIN as they call it
jjla2004
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 27, 2012
jjla2004
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1925
Points
5
My door leaks at bottom of freezer side. I spent a long time trying to figure it out as it does not doing it all the time. I finally noticed ice in the bottome of the freezer. When it is on defrost, it melts the ice and it runs out the bottom of the door. It leaves a very large puddle of water on the floor. I removed the panel on the inside back of the freezer. The bottom had been pushed back when some one put a turkey on the bottome shelf and shoved it back. The ice stopped and the water stopped for about 3 weeks. Now it is
doing it again and I can't figure it out. You might find something I never.
1helpful
Water dispenser has ceased dispensing water.
Water tube is frozen inside the door. Bad design. I use boiling water, a small plastic flexible tube and appropriate plastic syringe to force very hot water into the tube pushing the small tube into the dispenser tube. At some point it will stop because of the Ice blockage, more hot water through the small tube will soon unblock the line. A retrofit "heater" was available at appliance parts stores. I installed one. It stopped working and I haven't bothered with another. The Ice supply line is separate from the water dispenser and Y's somewhere to get water into the hinge for the door access to the Water dispenser in the door. Hope this helps.
2answers
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
1helpful
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
2answers
I have a Hotpoint HSS25GFTA BB. The water is not dispensing. I know the microswitch is making and water is pumping because I disconnected the tube on the bottom of the frezzer door and it squirts water...
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
Connected water supply and confirmed good water pressure. cannot get water to dispense or icemaker to make ice.
Hi, When you push the water switch in the door, do you the inlet valve humming? Is it possible that the wires came off the inlet valve?
If you remove the inlet valve from the cabinet and unhook the large size tubing that leads to the water dispenser, you can engage the dispenser lever in the door and see if water comes out.
I hope this helps you. Please let me know if I can assist yyou further.
Vic
2answers
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
1helpful
3answers
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
