Question about Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my virgin digital box to a hd box.i contacted virgin but the told me it was because digital has switched on.this shouldnt matter as this is quite a new tv package and was digital ready can someone help
    Sergeant:
  • 210 Answers
Make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Posted on Nov 07, 2009
6ya staff
SOURCE:
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
My samsung bd-c7500 dont play other dvd region than 3..i would like to unlock the dvd region to multi-region..how can i do that?
hi,
try the following
As I live in Kazakhstan my BD-C7500 is locked to DVD region 5. Just use the codes at the end of this tutorial for your own DVD region.
1. Ensure that there is no disk in the tray.
2. Switch the player on.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter 5 6 7 3 2 on the number pad.
5. The region code "3" should appear at the top left corner of the screen.
6. Quickly enter a "9" to make the player region free. (Just try pressing 9 on the remote controller until you see 9 appear in the upper left corner of your TV screen.)
7. Open and close the disc tray. Power down and power up again.
13. Play a foreign DVD to verify the change.
For people from other parts of the world, all region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
ok
Jan 12, 2011 | Samsung BluRay Disc Player BDC7500 BluRay...
DVD Player on my combo Sharp ejects the DVD
your cet is saying to you that it can only play dvd of a certain region.you need to purchase a dvd player that can play all region dvds. buy a samsung, panasonic or sony all region dvd player they will be able to play all your dvds.good luck.
Feb 27, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have a samsung dvd r 120, two dvd's i rented
Is it possible that the region codes of the DVD player and the DVD's are different?
Sep 10, 2009 | Samsung DVDR120 DVD Recorder
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
Wrong disk?
is the dvd multi region can it play disks from other countries if not find the codes for it by searching the name of the dvd player eg samsung unlock codes ........hope this helps
Jul 17, 2009 | NexxTech N600D DVD Player
Disc region error-DVP3146X/94
Its nothing to do with your pal format,its the region of the disks your trying to play,you need a region free DVD player
Apr 30, 2009 | Televison & Video
Code error country
insert the dvd disc from other region then the region code error will flash on the tv screen, then press the on screen button on your remote twice, then search search for the clock and set it to 0:00:00 and enter and it will automatically play.
Jan 09, 2009 | JVC XV-N320 DVD Player
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Nov 02, 2008 | Samsung HT-X250T Theater System
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Feb 02, 2008 | Televison & Video
Samsung LE32R72BX 32 in. HD-Ready LCD TV Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
