Question about Samsung LE32R72BX 32 in. HD-Ready LCD TV
Factory reset Menu
LOST DIGITAL MENU
How to get the 'SERVICE MODE' menu
    Sergeant:
  • 210 Answers
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Posted on Nov 07, 2009
  • Anonymous Nov 28, 2009
    here are some codes to try if the tv need code to enter some menus 1234 or 0000 or 5555 and 8888 these are manafactory codes for most tv / dvd / phones / video
6ya staff
SOURCE:
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
I need to access the service menu without the remote
You can't enter its service mode, without a remote control. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Samsung LN37A450 LCD TV
Clear/stop 1, 0, 7 color start does not work
Each menu is classified into two "Modes" depending on how you enter the service menus.
"Menu Mode" can be executed by pushing a sequence of keys.
"Special Mode" can be executed if you press certain keys at the same time as you turn the power on.
Each menu is classified as follows:
Menu Mode
Maintenance Mode Menu This is a menu for maintenance and service.
Special Mode
Fax Service Test Menu This is a menu for checking the fax mode.
MAINTENANCE MODE MENU
Selecting an Item
To select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous Level
To go into the next level of an item, select an item then press the "OK" key.
To return to the previous level of an item, press the "Return" key.
Exiting the Maintenance Mode Menu
To exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
"Ready" display appears.
For clear SC 543 Enter the engine maintenance mode.
Press "O.K" in "Fuser SC Reset" with engine maintenance mode, and then turn the main power switch off and on.
Oct 08, 2013 | Ricoh Aficio SPC232SF All-In-One Laser...
Clear/stop 1, 0, 7 color start does not work for getting into service mode?
Menu Mode
Special Mode
Selecting an ItemTo select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous LevelTo go into the next level of an item, select an item then press the "OK" key.
Exiting the Maintenance Mode MenuTo exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
How to change the color mode on nikon d50
here is where to find the settings
press MENU button
select Shooting Menu (camera icon)
select Optimize Image
select Custom
the color mode is here. mode 1 is standard RGB
mode 11 is Adobe RGB
mode 111 is for custom color settings, it allows you to increase/decrease a number of settings relative to color.
once you make a change be sure to press the "done" button or your changes will be lost...
Jan 12, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
My camera says my card is not initialize
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Aug 04, 2010 | Fuji FinePix A350 Digital Camera
Card not initialized? how do I initialise this?
Thank you !!
Jul 07, 2010 | Fuji FinePix 3800 Digital Camera
Switching folders
Press and hold display/menu to enter the menu mode
Press left or right arrow to select folder then press play
Press stop to exit menu mode
Mar 27, 2009 | Sony ICDP620 Digital Voice Recorder
Pentax Optio WPi lost program mode
It is 12 years old - replacement will be far more cost-effective than service or repair.
Aug 22, 2017 | Pentax OptioWPi Digital Camera
Samsung LE32R72BX 32 in. HD-Ready LCD TV Logo
5,315 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
