The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator or rotor may be defective.
LE code means locked motor error. you need to check the Hall Sensor. unplug the power, remove the rear washer panel, locate the Hall sensor connector on the stator behind the rotor. you can test it with an OHM meter for failure. it may just be an unstable connection.
Hello &
Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall effect sensor is used in these washer which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when
their is an issue with the motor or when the hall effect sensor sends wrong
signal to the control. Conclusion is you'll have to check both motor and hall
sesor and replace the part# that is bad, usually I have seen the sensor going
bad. Please get back to me if you have any other questions.
Kevin
