Question about Toshiba 65HM167 65" Projection Television
I have a toshiba 65hm167 no red color on the screen
I have a toshiba 65hm167 the other day all the red went out and now there is only blue and yellow color. I chanced the bulb only to find out that there is not 3 bulbs, red, green and blue but one 150 watt bulb. Well the color is the same just blue and yellow shades.
    Sergeant:
  • 271 Answers
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Posted on Nov 08, 2009
    Sergeant:
    Champion:
  • 433 Answers
Broken color wheel
Posted on Oct 28, 2011
6ya staff
SOURCE:
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
No red on my toshiba 65hm167 tv
not good, check all inputs etc, the model is a Dlp set so if loss of one color etc a Bad Optical Light engine is likely.
Dec 23, 2012 | Toshiba 65HM167 65" Projection Television
Replaced lamp and i still have a yellow light and no picture
Check that your lamp fan is working. It may also be a bad ballast for the lamp.
Mar 08, 2012 | Toshiba 65HM167 65" Projection Television
Faint red color on screen
blobby in appearance? or just a full screen or faint red
Dec 21, 2010 | Toshiba 65HM167 65" Projection Television
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Toshiba 65hm167 black screen with video input
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
Nov 02, 2009 | Toshiba 65HM167 65" Projection Television
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Yellow, blue and red lights
This could indicate a temperature problem. Make sure the lamp fan is running and that
none of the vents on the back are blocked. If you place your ear near the lamp access
door you should be able to hear the fan.
Sep 04, 2008 | Toshiba 65HM167 65" Projection Television
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Toshiba 65HM167 65" Projection Television Logo
553 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
