You can crack the software by getting a crack to any cracking websites in the internet. Just look for it there cause in here we don't provide it. Sorry..:-)
is there fuel coming out of filter. with it being a vortex motor it could be the fuel pressure is too low to open the fuel injectors or you have a cracked fuel line inside the intake manifold and not allowing the fuel to go out the injectors.
Listen closely to the drive, if it sounds like it is clicking then it is
probably not getting enough power through the USB. If you
received a cable with a split dual USB plug for extra power make sure
that both large USB plugs are in the computer while the smaller one is
attached to the drive, this will give it enough power to start working.
If it is not clicking and has plenty of power then it could be that it
is mapped to a drive letter that is already in use. Under device
manager, (right click my computer and select manage then click on disk
management) If you see the device in there then you can right click on
the bar graph representation of the disk and select to change drive
letter and paths. This will allow you to remove the conflict and have
it show up again.
Escuche atentamentea la unidad, sisuena como queest? haciendo clica continuaci?n,es probable que noreciba suficiente energ?a el?ctricaa trav?s delUSB.Si usted recibi? uncablecon un enchufe dedivisi?ndualUSBpara la energ?a adicionalasegurarse de quelos dosgrandespuertos USBenel ordenador mientrasel m?s peque?oesconectado a la unidad, estole dar?la energ?a suficientepara empezar a trabajar.Si no eshacer clic ytieneun mont?n de energ?a, entonces podr?a serquese asigna a unaletra de unidad queya est? en uso.El Administrador de dispositivos(clic derechoen Mi PCy seleccione Administrarcontinuaci?n, haga clicen Administraci?n de discos)Si usted veel dispositivo en elquesepuede hacer clic derechoen la representaci?ngr?fica de barrasdeldisco y seleccionara cambiarletra de unidady rutas.Esto le permitir?eliminar el conflictoyque se muestrede nuevo.
2 puertos de salida de audio para aud?fonos/bocinas
1 puerto de entrada de audio para micr?fono/l?nea
3 puertos USB
1 puerto VGA (monitor, proyector)
1 puerto de expansi?n
1 puerto RJ-45 (red)
1 puerto RJ-11 (modem)
1 bah?a PC Card
1 puerto S-Video *depende del modelo*
1 Lector de memorias 6-en1 *depende del modelo*
1 puerto 1394 (firewire) *depende del modelo*
Para quien tenga este problema con estos mp3 y todav?a no lo haya tirado, esto es lo que hic? yo el otro d?a que lo encontr? por ah? tirado:
- Quita la bater?a del mp3.
- Pulsa los botones de "Func" y "Play".
- Sin soltar los botones, conecta el mp3 al usb del ordenador.
- Aparecer? un mensaje para formatear el mp3.
- Suelta los botones y pulsa el bot?n "Rec".
- El mp3 comenzar? a formatearse solo y volver? a funcionar.
Espero que os sirva. Un saludo.
First of all, sorry for my English
If you still have this mp3 or for anyone who sees this solution, this is what I did:
- Remove de mp3 battery.
- Press and hold down de "Func" and "Play" buttons.
- Connect the mp3 to computer's usb.
- A message of formating the mp3 will appear.
- Release de buttons and press de "Rec" button.
- Formating will start and in a few seconds the mp3 will work again.
Hope it works...
Para quien tenga este problema con estos mp3 y todavía no lo haya tirado, esto es lo que hicé yo el otro día que lo encontré por ahí tirado:
- Quita la batería del mp3.
- Aparecerá un mensaje para formatear el mp3.
- Suelta los botones y pulsa el botón "Rec".
- El mp3 comenzará a formatearse solo y volverá a funcionar.
Hope it works...
Me disculpo por mi español pobre, yo estoy usando un traductor en línea.
Honeywell compra Metrologic, y que actualmente no ofrecen ninguna documentación en español para este modelo. Si eres capaz de leer Inglés, aquí es un enlace para descargar un manual de usuario. Siga este enlace a la página de soporte de Honeywell en español:
Hope it works...
Hope it works...
