double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
It depends on what the problem actually is; are the streaks colors like red or blue outlines around lettering etc?
The more you tell me the better I can help. I will post a photo or two of what convergence problems look like. This set is also prone to another problem, on a blank video input look at the screen: you should only see Video 1 (etc) and if you see faint curved lines (red, green or blue) and or the back ground is also wrong color you have the second problem.
let me know which it is.. If this information helped you rate this solution as very helpful as I do this here for free.
The conversion ics are probably going bad another common problem with this unit is fluid leakage on the convergence module this might be the problem also you must start out by seeing if that is the case both problems are repairable
Chances are that the convergence amps are bad. If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
