My Canon digital IXUS 870IS sometimes smokes when the flash is used? Is this normal?
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
SOURCE: Can the canon ixus 80 is be used as a webcam?
It may be able to be used that way (but its pretty iffy)...you would have to have to have a computer with an RCA-type video in jack (or an installed TV tuner card with the same RCA-type video in jack).
And if you have that setup on your computer, then you could use the AV cable that is supplied with this camera to send video out (either what is being shown on the screen in shooting mode, or already taken pictures/videos in playback mode) to your PC.
You would then need to point whatever software you are using to broadcast your webcam stream to the "video in" jack as the source of your webcam video (if it even allows for that option).
If you can do all that, it MIGHT be possible, but its probably a pretty long shot.
SOURCE: Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
SOURCE: canon digital ixus 850is card locked! message
.....Open your memory card........Adapter And see There IZZ a ThiNg named Lockand UNLOCk That!!!! i guEsS that woULd Work.....
Testimonial: "many thanks for unlocking my card Is is an 8g card expensive for a pensioner. it had just a few photos on it. Thankyou again Peter"
