Re: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Look for something like this at your favorite electronics store...http://www.bestbuy.com/site/eForCity+-+3+Way+Audio+Video+AV+RCA+Switch+Switcher+Splitter+with+Cable/4655143.p?id=1218501028155&skuId=4655143&st=AV Switch&cp=8&lp=3 Copy all of that into your browser and you'll end up at best buy looking at a A/V Switch that can switch between 3 different devices so you don't have to change the cables...also, look for ones that are remote controlled that have more options...I just included this one as an example...hope this helps you!
8 blinks in KLV-32S400A shows Audio Error Check audio voltage supply from power supply board, if OK, replace GP Board (main board) and if audio volts are not available, check/ replace power supply board.
Had the same problem with mine.
Took off HDMI cable and used the HD cable (Red Blue and Green) for video and standard (red and white) cable for audio.
Problem gone
