Master
- Posted on Nov 08, 2009
Re: Leaking from the bottom of the glass container...
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
