If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
