Toshiba 50H82 50" Rear Projection Television Logo
Posted on Jul 11, 2017
All icons open itunes has something to do with the
Today, i accidently changed the "Open With" funtion for all of my desktop icons to itunes, when i was only trying to fix the itunes icon. Now when i double click on any icon, i.e. Mozilla Firefox (the icon for mozilla is the itunes icon) it opens itunes instead. How do i fix this? Literally every single desktop icon, even Microsoft Word and Microsoft Publisher open Itunes instead of their designated applications. Please help!
1 Related Answer
Anonymous
  • 87 Answers
  • Posted on Nov 03, 2010
SOURCE: Today, i accidently changed the
This will work, it's a little time consuming and there may be a faster way I am not aware of, but this way is sure fire to work. I assume your operating system is Windows because of the "Open With" comment. First thing you have to do is find where the .exe file for each and every program that is affected actually resides. For example you MIGHT find the .exe file that runs word in c:\windows\microsoft\office. That is just an example, the actual place depends on several different things like which OS you actually have, whether its 64 bit OS or 32 bit OS and if you specified a different folder when you installed it. Second you can either delete the shortcut and make a new one by right clicking on the actual .exe file for the program and clicking on create shortcut OR you can right click on the shortcut you already have, click on properties, and type the path to the .exe in the text box labeled "pointer" or "points to" or something similar.
How do I rename my ipod?
When registering your iPod, iTunes will ask you to give your device a name. If you choose not to give your iPod a unique name when configuring the device, iTunes will often give your iPod the default name of "Owner's iPod." If you grow to dislike your name, or were gifted a used one, changing the name on your iPod is very simple. You can change the name of iPod to whatever you like. Your imagination is your only limit.
Connect your iPod to your computer using the USB cord. iPods will only work with specific USB cords. If you have lost yours, you can purchase a new one from most electronic stores. Open iTunes. While iTunes usually opens automatically when an iPod is connected to your computer, sometimes that fails to happen. Double-clicking on the iTunes icon (you should have it on your computer's desktop) will open iTunes. Scroll down and left-click on the icon for your iPod. You will find it in the left hand-side panel of iTunes. Left-click on the current name of your iPod to highlight it. Type in the new name of your iPod and then left-click anywhere to save. Change ipods owners name http://www.amoswong.com/how-to-change-ipod-owners-name.html
1helpful
I have a Freecom 160Gb external drive which I've used to back up various files (mostly photos and iTunes) which were loaded on the pc with Windows Vista installed. The pc recently had a failure o
Windows-based PCs b> Plug your iPod into your computer to open iTunes; if it doesn't automatically open, open it manually. A window will pop up on your computer asking you if you want to sync the contents of your iPod with the contents of your iTunes library. Click cancel. In the iTunes source list, choose the iPod, and make sure that you have selected the Summary tab in iTunes' main window. Open up the My Computer icon from either your desktop or the Start menu, and select your iPod from the window. In the My Computer window, open up the Tool menu and click on Folder Options. This will open up another window. Choose the View tab, and find the heading for Hidden Files and Folders. Click on the button that says "Show Hidden Files and Folders," then click the "Apply" button at the bottom of the Window. Close the Folder Options window. Find the iPod's icon on the desktop and double-click it. This will open more folders in the iPod window. Find the folder called iPod_control and double-click it. Now you will have a number of folders to choose from. Locate the music folder, and drag it to the main desktop so that it's copied to your computer. When the Music folder is on the desktop, right-click on it. From the window that appears, choose "Properties." In the Attributes area of the General tab, uncheck the Hidden option, and then click "Apply." A window will appear that will ask you to confirm the attribute changes. Make sure the box next to the Apply Changes to this Folder, Subfolders, and Files option is checked, and then click OK. Drag the folder and its contents into the iTunes library.
b>
Itunes is changing my desktop icons when i install it
Contact 1-800-204-4427 iTunes technical support phone number is a fast and easy way to resolve all iTunes account related issues, iTunes Support Phone Number 1 800 204 4427 Tech Help
When i download itunes on my vista home premium acers aspire laptop, all my desktop icons convert into itunes icons and only run itunes. HELP!
go to the control panel select default programs. select itunes on the left and choose defaults for this program. let it load the list and then untick the boxes
1helpful
Today, i accidently changed the "Open With" funtion for all of my desktop icons to itunes, when i was only trying to fix the itunes icon. Now when i double click on any icon, i.e. Mozilla Firefox...
I downloaded itunes on my new laptop. Once downloaded all of my icons I open, open Itunes? they also have the itunes symbol next to each one??
When installing, many programs associate file extensions in Windows with the program. In your case, iTunes associated all file extensions it supports with itself, hence the icons.
Depending on the Windows version, you can change this in the Explorer, or using the default program options (Vista & Windows 7).
Ipod code -48
http://forums.macrumors.com/showthread.php?t=441299
Try that link i suspect they will be better able to help you then we can here, Might be wrong on that but try the link
My iTunes wont install correctly after a problem with a different
You may want to try the following :
1. Right click on the Itune icon
2. Click properties
3. Select Compatibility
4. Under privilege level, Un check "Run this program as an administrator"
when you start it up it still say "would you like to allow the following program to make changes to this computer"
5. Restart the computer
You may also see this link with a similar issue : http://discussions.apple.com/thread.jspa?threadID=2233335&tstart=15#10578385
The desktop icons have all become the itunes icon and all shortcuts open itunes. i can't change them because it says i need administrator accces, but i am the administrator
This seems to be a known issue that has been experienced by other users. I recommend you try to uninstall the Itune that you installed in your computer. Try to check this website or forum that I found, this could be helpful for you.
http://discussions.apple.com/thread.jspa?threadID=2054232
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
