I have a yamaha clavinova CLP200 the amp has lost all it's power.you can hear the keys through head phones but very quiet. the volume control has no efect
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
I assume you have adjusted the KBD volume.
IF YOU HAVE NOT then that MAYthe problem.
Refer to page 17 of your manual or download the manual here:
http://www2.tntech.edu/bfa/piano/clavino...
Adjust the KBD volume to 127 and try it.
This setting MAY be overriding your volume control.
