Olevia 537H LCD - was messing with the menu the other day and I think I hit the Auto Sync under the Picture menu - I noticed an immediate change in color - now I can't manually change the tint, color, brightness, can't get out of showroom mode - seems alot of the options I could manually get to before are now disabled. Tried to reset factory settings but that would register either. I continue to get the green square around the options I want to change - can't get it brown/gold which would indicate I can change it.
No idea what happened but about an hour after posting this the TV started to function properly - now I can switch everything that was previously lokced up. So I'm all good - hopefully it doesn't do it again.
What is the code for direct tv?
DId you do anything special? I am having the exact same issue and can't seem to customize my tv.
No I just kept going in to the menu options and it just started working again. Bizarre - keep messing with it and hopefully it will work again for you.
