Dell OptiPlex GX260 PC Desktop Logo
Posted on Nov 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Anonymous
Level 3:
  • Master 788 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
Answers
788
Questions
0
Helped
253946
Points
2355
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Anonymous
Level 2:
President:
  • Expert 1,257 Answers
  • Posted on Dec 20, 2009
Anonymous
Expert
Level 2:
President:
Answers
1257
Questions
Helped
1179444
Points
168
My sony cdrwdvd crx880a won't burn cd's.
google windows dvd fix and see what that comes up with first. if not you can go to a local it shop who can replace for you very simple job only cost about £20 for a reatil boxed but ask if they will put a OEM in will b cheaper
Dell inspiron 1525 blank dvd r not regognized
You will need to use a different brand of blank DVD-R disc, some DVD-R disc will not work with some optical drives. Try using a Sony or Phillips DVD-R discs, these two brands work best.
Computer does not recognize battery
I know exactly what the problem is. The problem is that the motherboard is not reconizing the charger.The motherboard will need to be replaced along with the charger. I recommend calling Dell Costomer Service. That number is 1-800-847-4096.
Mouse froze now willnot switch on
Hello Sir, Hi, try removing the battery, and replug it again.
I have a dell inspiron with a tsst corp cdrwdvd 462D ata device. I keep getting the messagae that my device drivers are corrupt. I have uninstalled the drivers and tried to reinstall them but I continue to...
Even though you are getting the message, do the cdrwdvd work? Sometimes, viruis will display message to get you to go to certain website for MORE viruis. I would recommend using Dell support website to update your drivers from there.
Good Luck
C2Solutions
2helpful
4answers
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
1helpful
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Error message
That is not an error, Windows is trying to verify that there are no issues with your hard disk. Is what you wrote above all that you see? If so then check disk is freezing before it completes. Try to cancel the chkdsk before it starts by pressing any button when it prompts you to, log into windows, back up everything up that you need and restart your laptop. Worst case scenario you need to reinstall windows on your laptop
Burner problem
You will need to reinstall the driver. Go to dell.com...you can download it for free.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlo_032032486ea0d83f
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
