Have no sound for TV, everything else is fin. Just moved it to another room, where it has been fine for the last few months but now no audio at all
First check to see if you get it on all inputs (DVD, Cable, etc.). If you get no sound on all inputs, then do a hard reset by unplugging the TV from the wall overnight and plugging it back in and test again. If this does not work, then the main board needs to be replaced.
If you do not get it on all inputs, most likely it is just a loose connection. Check the connections going out of the source and into the TV for something that might have come loose. If everything is okay, test the bad input with something that you know has some on a different input on the TV. If this still does not work, replace the main board or simply do not use the bad input.
