My Bush 32 inch LCD tv. clicks on for a moment then goes blank. Any answers?My Bush 32 inch LCD tv. clicks on for a moment then goes blank. Any answers?
My 27" LCD decided to stop working tonight, the screen went blank and the sound was distorted, I switched it off and then tried turning it back on, red standby light is flashing continuously, no response from any buttons.My 27" LCD decided to stop working tonight, the screen went blank and the sound was distorted, I switched it off and then tried turning it back on, red standby light is flashing continuously, no response from any buttons.
AnonymousFeb 15, 2008
standby button continuously flashing with no sound or picturestandby button continuously flashing with no sound or picture
AnonymousApr 05, 2008
standby red light flashingstandby red light flashing
AnonymousJul 20, 2008
Red standby light flashing, but unable to get the tv to go on. I have turned off but to no availRed standby light flashing, but unable to get the tv to go on. I have turned off but to no avail
I had this problem so I bought a new PSU and fitted it and I still have the same problem????I had this problem so I bought a new PSU and fitted it and I still have the same problem????
have u try turning the tv off, and taking the wire from sugit, for 15 second, while holing down on the power butten.
then pug it in and leave it for 10 second. before puting it on that mite workhave u try turning the tv off, and taking the wire from sugit, for 15 second, while holing down on the power butten.
You can't post conmments that contain an email address.
The II2 Bus has the fault. It detects some malfunction from other circuit boards. Your TV need a through checkup. Contact any experienced service technician, as the work is a very skilled one, and not a user reparable.
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Since the TV is still receiving power, the problem is going to be with the TV's mainboard. After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again? The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation. Don't forget to provide them the error code or 4 flashes repeating.
My Olevia LCD TV did the same thing. I turned off the back power switch and pulled the power cord as well. Left off for a couple of minutes and then re-connected cord and turned on main switch. I then turned on the front power switch and it come on just fine. These new sets have computer-like guts so you have to re-boot them sometimes. I hope this works for you.
Dear Sir,
unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution.
This job definitely requires a professional technician
Best regards,
Arpi
Me too my bush tv keeps going into standby
