Master
- Posted on Nov 09, 2009
Re: I'm tryin to install the sierra wireless card 598 on...
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
- you may need the sierra CD device driver that comes with your wireless card.
- next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
- depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
- run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
- after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
